    Dismiss Notice
Hardwood decking, which screws/hidden fixings.
Discussion in 'In the Garden' started by RickyLee53, 24 May 2014.
  1. RickyLee53
    RickyLee53
    30 Jun 2012
    130
    Thanks Received:
    2
    Yorkshire
    Country:
    Hello,
    Today I've tried to lay some hardwood decking (in between the rain). It is Red Balau hardwood.
    I purchased some "clips" which go into the side of the decking and are concealed. However, they are very flimsy, and more or less impossible to hammer into the side of the boards without bending. I think they are made for softwood.
    There are some fixings that you can biscuit joint into the sides, but they are expensive, look labor intensive and are plastic.
    Can you 45 degree into the sides of the boards? If so, i'd need a super small head on the screws.
    Has anybody used these? Are there any type of jigs for side screwing. (i've seen ones in the states but nothing in the UK)
    http://www.free-instruction-manuals...ree-instruction-manuals.com/pdf/p47111670.pdf
    I have over 30sq meters to put down.
    Thanks for any help.
  2. r896neo
    r896neo
    23 Feb 2007
    4,767
    Thanks Received:
    779
    Belfast
    Country:
    • Thanks Thanks x 1
  3. Sponsored Links
  4. RickyLee53
    RickyLee53
    30 Jun 2012
    130
    Thanks Received:
    2
    Yorkshire
    Country:
  5. r896neo
    r896neo
    23 Feb 2007
    4,767
    Thanks Received:
    779
    Belfast
    Country:
    If you lay them butted the uneveness as they shrink is much more noticable.
    i.e a 3mm gap opening to 5mm is less of an issue than a 0mm-2mm
    Either invest a few quid in clips that work or go for the face fixing as normal.
    The small spax at least are not as obvious.
    I can't offer any reviews or advice on clips.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. RickyLee53
    RickyLee53
    30 Jun 2012
    130
    Thanks Received:
    2
    Yorkshire
    Country:
    I did some experimenting and you are correct. Face fix is the only way. I've read a few reviews on clips and cannot see anything that looks suitable. There are a few boards that aren't straight so I'd have no chance with most clips. Good point on the spacing. I'll let you know how I go on tomorrow.
    Thanks for your help.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
