Hi everyone, hope there's someone on here who knows the gearbox of a Yale composite door inside out!
Mine were fitted 2 and a half years ago and for the past year or so, one of them has been a b****r to lock. Presumably due to misalignment the key would be very stiff to turn and sometimes outright refuse to lock unless you rammed the handle up really hard (it locked fine when open).
Now it seems all that forcing has worn away at something because I now have a worse problem in that sometimes even if it seems I've locked it, it opens again anyway! Lift handle, turn key *click*, check handle and it goes back down again
Often it requires quite a lot of fiddling to get it to actually stay locked and now the trick seems to be to turn the key the other way!
So what, do I need a new gearbox or can it be fixed? I think the doors are from the superior series, the cylinders certainly are as they have the same sort of key as Garrison/MulTLock.
