Compression Fitting question
13 May 2015
London
Trying to add a bidet shower hose to my toilet. Am stuck at the joint as to what I would require to join the tee compression with the toilet tank. I have seen in you tube videos that the copper pipe slides in the tee compression hole but I got a piece of copper pipe and it just doesn't go in the hole for tee compression hole. Any suggestions welcome
Image for the current fitting at the following link
https://www.flickr.com/photos/65231752@N00/16973879803/in/dateposted-public/
[/b]
Sorry that is all wrong, :( the union on the end of the isolation valve is designed to fit the tail on the toilet which is flat, the tee has a thin tapered seat and although it will sometime work it is not designed for that it may well cut the washer.
You need to insert the tee in the pipe below the isolation valve. Very tight for space though, you may well need to remove some of the trunking.
I would replace the isolation valve too, firstly because the washer may have been damaged (they have to be just perfectly lined up and not overtightened) and you might be able to find a slightly shorter one if you shop around to give a bit more space to work.
just wondering how many water regs u might break by teeing your bidet into that supply :?: :wink:
