My Victorian terrace has a drain in the cellar that became blocked recently. We're not putting much into it (washing machine, condenser dryer, condensing boiler) but at some point in the house's long history, some moron has poured a load of cement down the drain.
A plumber was able to unblock the drain today but the pictures show the issue:
I'd break this up with a hammer and chisel but the drain isn't easy to access:
Here you can see 40mm pipe from the boiler and the washing machine/dryer. The hole is around 500mm x 400mm in size. The drain is positioned around 400mm from the entrance.
Breaking up the cement by hand is a possibility but will be very difficult to get in there and swing a hammer. Are there any chemical options that would go to work on the cement without totally wrecking the drain?
How much would I be looking at to replace something like this? At some point in the next 5-10 years, we'd like to renovate the cellar and turn it into habitable space anyway so I have no interest in spending a massive amount to get it fixed.
