I'm going to lay a concrete floor inside a large house. It will be approx 200m2 in two sections of 100m2 joined by two interconnecting doorways. My idea is DPM, 150mm concrete slab with 6 or 8mm diameter mesh mid-level, 120mm celotex or similar, vapour barrier, 50mm liquid screed enclosing CH water pipes. There's a lot of digging out first because I want the finished level to be at the same level as the oversite concrete that lay under the original suspended timber floor -- we are lowering the original floor level by about 450mm.
Question: does this construction sound suitable? Some people are saying we need crushed aggregate/hardcore under the 150mm slab. Other people are saying that if the concrete slab is reinforced with mesh (we might get those special fibres in the mix too to strengthen it further), there is no need for any aggregate under the slab. Any advice please?
