Hi
We’ve ordered a summerhouse, about 2.2x2.2m square. It will need a concrete pad to sit on and wre considering doing this ourselves.
I’m seeing conflicting advice online and from tradesmen too. I read that it needs 100mm sub base (mot type 1, compacted) and then 100mm concrete pad, with membrane underneath, and ideally a concrete mesh suspended on the inside for strength.
I’ve been told that I don’t need the mesh - overthinking - and that for this type of low weight, structure, the sub base isn’t needed. Ie compact the ground with a whacker, concrete pad on top.
I’m not really sure what to believe. Sounds logical that something light doesn’t need a super foundation but then equally I don’t want to have to ever worry about it moving or cracking!
Plus, the membrane, is that simply an impermeable plastic sheet laid on the ground, concrete directly on top? Of course I’ve seen this on Google but want to clarify my understanding.
Does anyone have experience or advice surrounding this? Many thanks.
