Hi All,
I'm in the process of digging out a 7.5m x 4.3m (32m2) plot to stand a concrete base for a summerhouse, the overall depth of the plot varies slightly from 150-250mm from where the garden slops in both directions
My plans are to make use of the piles of general hardcore and rubble i have to clear by filling the majority of the depth then to spread a number of bags of MOT Type 1 over the hardcore using a compactor to form a fairly level base, then to blind with sharp sand to fill in any voids on which to lay some DPM then pour the concrete in one go
Based on the above I would expect the actual depth of the concrete part to be anything from 75-100mm once i have a fairly compacted base
I have a few questions / concerns
Is my plan to fill the gaps with MOT and blind with sand a good idea when i could just fill the voids with cement, am i saving money on cement by doing this?
MOT = £40 per tonne, Cement - £120 m3
Do i need to add A142 steel reinforcement mesh with a fairly shallow concrete slab? its not a garage so minimal weight
Also is it wise to add a damp proof membrane between the compacted base and the slab, cutting this out would save me the costs of the sand and DPM
Thanks for any input
Andrew
p.s Mods please move to Building is this is more relevant thanks
Andrew
