Concrete path to high against DPC - what is the solution?
21 Mar 2004
The concrete path against the side of my house is too high, covering some of the DPC, the concrete is also cracked in serveral places. There is also a drain against this side of the wall with a removable box that sits on top of the drain as a cover, underneath there are 2 open ended plastic pipes(both look very rickety) that flow waste/water into the drain.
Any ideas on the best way to go about fixing this with the outcome being as cheap as possible and a new pathway leading to the garden?
Also do the pipes sound like they need to be replaced aswell (latest building regs etc)- wondering if there is any way that they could be moved under the surface so that you only see the drain cover not the exposed waste pipes too?
Thanks & Cheers
M :lol:
The proper way would be to dig it up and relay it 150mm below damp. You will find waste pipes in older houses do look a little worse for wear after a few years, I would not advise in trying to put them underground, just make sure they are clipped back neat and tidy
