I looking at redoing the central heating, to save money I will be doing as much of the donkey work as possible, as I am quite happy to remove floor boards and fit pipe work myself over a period of a few days.
One thing I would like to do is plumb everything up to the boiler manifold ready for the plumber to turn up and plop the boiler in place and do the complicated stuff.
My question:
Let me try and describe the situation. I live in a semi-detached house, if you imagine the roof is designed with no gable ends, so roof slopes up to the centre of the two properties where the chimney breast is.
However on the front of the house, is small gable end. Very similar to the below pic:
https://www.edulink.networcs.net/si...chlearn/designtech/Gallery/Stimulus/Buildings
Ours differs in that there is no bay window upstairs, so imagine the triangular roof parts flush with the rest of the house. Now there is a guttering down pipe from the roof to a drain that runs straight down the centre, of the two houses, with a "hopper" bit at the top.
I intend to fit the boiler in the loft space in that triangle on the front of the house. Is it ok to run the condensate pipe from the boiler internally to the corner and fix the pipe through where the roof meets the top of the wall to drain in to the guttering "hopper". The hopper catches rain water from the two gable roofs.
Thank you for any help,
Jason
My question:
Jason
