condenser dryer tripping out
18 Aug 2011
Gwent
Hi folks have an indesit is70c condenser dryer ,it would not spin took sides off cleaned and moved belt .This worked for a while then tripped the rcd on fusebox everything has been cleaned ,any help apreciated alan
Check the heater. It's broke or getting wet make sure condenser and pump are clean.
Hi rocks is the heater the element and where is the pump please the mc is at my nieces house cheers alan
All found at the rear. Just spin it around and remove the rear banjo for the heater. Pump is in the back left as looking from the front.
Hi rocks have checked all seems ok the drum spins for about 15 secs then trips power .my niece said it would not spin until i cleaned filters etc and moved the belt ,could it be the motor cheers alan
Unplug the Heater then try it , if it don't trip it's the heater at fault.
