I daresay tonybhoy is spot on with his numbers.
But anyone who installs knows that the tables are miles out. Then the outlet of the meter is usually small, etc etc.
I usually work it out, then go the next size up!
FOr example, I just put in a 28kw combi.
20metres of 28mm pipe, all completely deburred, 10 elbows, and a little 22mm coming off the meter.
Drop shows the pipe is undersized. Go figure.
According to WB,30mtrs (equivalent length) of 28MM will deliver 4.7m3/h so you just about ok at 3.2 m3/h (30 CDI-30.9KW)
