Because they almost certainly aren't RCD protected you can't plaster over them unfortunately.
Best bet is probablly to use plastic trunking making sure the trunking has enough depth that you can neatly plaster up to the sides of it and yet still get the lid on.
I am having a similar problem. The tails are in trunking but 1) it is ugly and 2) the electrician didn't bother to make the trunking vertical, you can see with naked eye that it is lopsided. My CU is near to a corner. There is another trunking there for a radiator pipe, so I am going to box the whole corner before the plasterer come to skim the hall.
And beware of enclosing cables in the same construct as CH pipes - they might get too hot.
Finally, a generic useful tip for people retro-fitting trunking to cables (don't know how much use it would be to either of you, given plastering requirements):
If you are struggling to get the trunking under cables already installed, slide the lid under instead, and part the cables in a few places to screw it to the wall, then clip the body onto it. With larger trunking it's also a good way to quickly box in pipes.
Ah haa! Exactly what I need to do above my CU! Had you not have posted it, I wonder if this forehead-slappingly obvious solution would have actually occured to me before hacking off the sides of the trunking and trying to re-attach them later, or trying to make them hingeable with gaffer tape or something, or... hmmm...
