Hi folks
First, I'm not a plumber by any stretch of the imagination and I'm working things out as I go along. I've been having problems with the valve in my toilet cistern. I have bought one of these to replace it with:
http://www.screwfix.com/p/fluidmaster-bottom-entry-fill-valve-uk/84007
There was copper fixed right into the bottom of the old inlet valve and I decided to replace that with a flexible hose to make sure I could get a good fit to the new inlet valve. There is an isolation valve in the copper supply already, so I bought a bit of pipe, some olives, PTFE, pipe cutters and fibre washers.
The copper supply is 15mm. I measured the diameter of the Fluidmaster shank and it is 3/4 inch or 18mm. So I looked on Screwfix and I bought one of these:
http://www.screwfix.com/p/wras-hose-15mm-x-3-4in-x-1000mm-x-10mm/31385
Because it says 15mm and 3/4 inch. Everything's fine except the nut on the flexible hose is actually ONE INCH diameter. It says on the packet 3/4 inch and it gives instructions for connecting to a cistern. So I am confused. I have, perhaps stupidly, assumed that the 3/4 inch refers to the nut size, since the 15mm refers to the pipe fitting end size, the 1000mm refers to the hose length and the 10mm refers to the hose bore, which is all logical.
MY QUESTION: Have I by a million to one got a flexi hose with the wrong size nut in the wrong size packet? Or do I need to in fact get a 1/2 inch flexi hose to fit a 3/4inch diameter valve shank? If so, can you explain why that is? Or have I just bought the wrong kind of flexi hose altogether? If so, can you point me at the right one?
I hope someone can help me out fast, as my toilet is out of action and all the DIY stores are now shut as it is Sunday after 4pm. Unless anyone knows where you can get emergency plumbing supplies in Bristol on a Sunday evening??[/img]
