Having read the forums receiving some useful replies (thanks Richard C et al) and the obvious preference for skimming over plasterboard and moistureboard (after priming with ThistleBond-it
) I thought I would ask the manufacturers their recommended plaster for skimming on Lafarge boards. I received this :-
Dear Sir
I confirm that no pre treatment is required before tiling moisture board.
In respect of the skimming, we do not recommend a skim finish on moisture board. There is no point using a moisture resistant product and covering it over with a non moisture finish. Also the skim does not adhere to the surface very well and there is a chance it will 'shell off'. However if you still decide to skim you will need to pva the board twice and skim on the second coat whilst still tacky.
Regards
Lafarge Plasterboard Ltd
I found this odd as I was under the impression that skimming was actually the standard finish for plasterboard including moisture board. Plus as is clear from the forum PVA is not the best for priming MR P/b.
Should I let this influence me or is this not strictly true?
Regards
Paul
Dear Sir
Regards
Regards
Paul
