Hello
Could you give me a bit of info.
Been looking at a mates consumer unit that he wants changing he has a old reweirable fuse version and is looking to put a more modern version one in, i understand there could be a number of issues with the RCDs tripping on the new board, but there are two areas that i cant get my head round.
He has power running out to his garage via some Mineral cable this is currently run direct from a henley block before it reaches the consumer within the house, once it reaches the garage it enters a consumer unit with RCD protection and feeds a power and a lighting circuit.
He also has a feed from within the houses consumer unit via a 40amp fuse to the loft to a mini consumer unit which again feeds a power and a lighting circuit.
My question is this if the power runs from the henley block to the garage then shorely the only protection for the cable is the 100amp main fuse which doesnt sound right, for the loft it is protected by the 40amp fuse within the board, what is the correct method for routing both of these cables.
I would like to add that i am not doing this work and have advised him to get a qualified Electrican to do the work i am just curious to understand it all better.
Thanks R.
Thanks R.
