connecting a plinth heater
19 Oct 2005
I intend to replace a small kitchen rad with a Smith plinth heater but the recommended model (SS3) for the space (17m3) doesn't come bundled with flexible pipes & isolation vales like the higher BTU-rated models.
I found some 300/500/1000mm braided flexible 15mm hoses in B&Q but noticed they were rated at Max 70C / Max 16bar. These aren't tap connectors, they're proper 15mm compression fit at both ends. Are these suitable for domestic CH connection?
If not (or alternatively), should I just buy the higher-rated model (SS5), suitable for 29m3 which comes bundled with flexihose and restrict flow using the feeder valve?
NB. I'll be attaching this to an 8mm microbore open-vented system, presumably via reducers.
I've never worked out why they don't supply the appropriate hose with the SS3 :?
Others will probably disagree, but I always specify the SS5 to get the supplied hoses with isolators buit in and they are push fit :wink:
Thanks for the advice. Could you estimate the length of the hoses? I'll have to screw around a bit to mate them with the existing 8mm microbore...
