I have a thermostatic shower fitting and I have the h& c feeds already installed 150mm apart in the wall behind the tiling. The 'bar' has 3/4" BSP female connections (I have two of different makes and both are the same), but what do I use to connect them to the 15mm copper? I can't find any mention of what to use in the instructions (it just says 'connect them...' - not much use). The connections look as if they should use rubber or fibre washers, but I can't find the correct fittings to use. Can anyone help, please, as there doesn't seem to be a suitable 15mm or 22mm fitting to convert from the copper.
