    Dismiss Notice
concealed shower valve connection
Discussion in 'Plumbing and Central Heating' started by catfordbags, 4 Aug 2017.
  1. catfordbags
    catfordbags
    19 Sep 2007
    28
    Thanks Received:
    Country:
    Hi all - I'm fitting a concealed shower and just thought I'd see if I can get some confirmation that I'm attacking it in the correct manner.
    The shower ... https://www.victorianplumbing.co.uk/astoria-traditional-concealed-shower-valve-inc-8-head-with-arm
    The valve is vertical with two taps. To centre the valve in the shower it sits close a stud. The hot and cold feeds are either side of the valve with 1/2" bsp female fittings.
    My plan is to fit 1/2" male x 15mm connectors. Then very short run of copper, 90 degree compression elbows and lengths of copper heading down towards the poly pipe coming up out the floor. Is this a sensible approach or is there a better way ?
    Also not sure whether to connect copper to polypipe direct or perhaps use 15mm x 15mm flexible hose ?
    Many thanks in advance
    CB
  2. Sponsored Links
  3. PullerGas
    PullerGas
    11 Jul 2015
    6,062
    Thanks Received:
    1,205
    Glasgow
    Country:
    No reason you couldn't just do as you suggest & fit two push fit elbows, space permitting.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
