Hi all
Recently had a Aerotherm Plus heat pump and cylinder installed. It includes the Sensocomfort and I was surprised to see that something of this day and age doesn't include remote access as standard. Anyway, I went and purchased the internet gateway (vr940f) to connect up. It comes as standard with the plug in point for the boiler which I don't obviously have. Am I right in assuming that I just need to ensure power to the unit (still to find out voltage) by connecting a suitable power supply to the screw in terminals, and then isolate the other 2 cables from the unit and connect up to the bus port of the sensocomfort? I already have an outside sensor connected there but I believe you can have multiple connections through the ebus terminal
A
A
