Connecting water supply to toilet cistern
8 Aug 2017
I am replacing a toilet. My water supply is from a compression joint about 15cm more or less directly below the cistern entry point which is a male plastic thread.
I had hoped to use a flexible connector but the shortest I have seen is 30cm which is too long.
What are the alternatives, please? I presume I need a BSP to connect to the plastic cistern thread and can not use copper pipe and olive?
Either cut out and plumb back in with fittings or try a 150mm flexi.
Thanks. I think a 150mm flexi will be too short. Been looking to see if I can buy a short length of copper pipe with a BSP on one end, then I could cut the other end to the length I want.......can't seem to find anything like this though.
I can't reduce the length of the water supply feed. It is just out of the wall by a few cms, where I have attached a compression isolating elbow.
Just pig tail the flexi, basically you are creating a coil out of the pipe that should take up the excess.
images
