When installing soil pipes for a bathroom, if it is necessary to have connectors in the floor space between the ground and first floors, are compression fittings good enough to last "forever" or is it necessary to use solvent types?
I am using plastic pipes and I am hoping that it will never (or at least for a very long time) be necessary to lift the floor or platerboard below to fix leaking connectors. I am also asuming that compression fittings are better than the push-fit ones
