I know that you can get soldered connectors, without central registers. (Are these called slip connectors??)
Can you buy compression fittings without the central register that can be slid along pipe for those who are not confident solderers. (I appreciate that carefull positioning is necessary to centralise them and that once tightened they cannot be removed)
Could you simply remove the central register of a standard connector with a 15 or 22mm drill.
