conservatory firrings needed
16 Jan 2009
Gwent
Hi All
Do anyone know a company that will supply firrings for my conservatory it seams like I've hit a dead end as I got the window and roof just need to fill the triangle gap between... or are they called something else
Hi All
What style of roof?
Depending on the pitch , you could have frames made to fill the gaps, or even build a wooden structure, insulate with Kingspan ( or similiar ) , then face with some Pvc boards ( such as hollow soffit ) . Or you could use ' Addons/Knockons ' which are usually the same with as the frame ( probably 70mm these days ) and literally just clip together , as they are designed to make a window frame bigger when either internal or external reveals require it. Obviously you will need to make up a rectangular section and then cut it to the angle you require
