Conservatory Insulation DIY stylee!
thanks for your reply and for the pics, After seeing what you have done im 100% behind it now, we spent 15k on our conservatory 3 years ago and we have very limited use of it. Doing the same as you should at least open the doors up for another 6 months at least. nice job well done. and £150 well you will save that in heating. thanks again. Take care and gud luck.
sorry just one more thing you said you put wall paper up and painted it, I just want to know how did you make it stick? was normal paper paste ok or did you use something else. thanks again.
one more thing did you get 25mm as that would sit flush with the beams or did you leave a gap between the roof. just want to make sure i order the correct size and dont make no mistakes. also how did you attach the boards did you use screws or did you use glue. thanks again for your help.
