I've just had a conservatory built and need to raise the screed floor by a minimum of 12mm to be flush with a waste manhole surround that had to be installed at the same time. I will then lay sheet vinyl.
Can anyone recommend a sheet material which would do the job (not too expensive!) and also give me any tips that might be useful to avoid disaster. Eg would I need a moisture barrier?
Also could anyone recommend a sheet vinyl that can be laid unglued (in case I need to access the manhole in the future).
