Conservatory roof panels
19 Feb 2016
Hi all,I was cleaning the poly roof panels on my conservatory and noticed that some of the strip's on the end of the panels that overhanging into the gutter have warped out of shape and one has come off the panel completely. Can I get new strips(sorry don't know proper name) and would they be easy to fit ? Thanks in advance
Found out the pieces I am referring to are called end closures?and I am wondering if I can remove the old warped ones and replace with new ones without removing poly panels?can't seem to add photos, new to this site,thanks
Ali ones are best as they don't warp in the sun. To fit yours back or new ones then remove the rafter end cap, sometimes screwed on sometimes slide on - depends which roof system, now the end closers can just slide on over the poly, if the breather tape is damaged or hanging off then now's the time to replace it, comes in different widths so you'll need to measure the thickness of your polys
Thanks for the reply crank39,sounds easy enough but what holds the end closers onto the poly panel?
Nothing other than slight compression although its always best to put a bead of quality silicone inside the top edge of the closer and then slide it on, i use soudal fix all, in crystal clear.......made for the job
Thanks crank39 much appreciated, another job I can get done.Still can't upload photos from my phone !!!!
