We have a small 3x3m Victorian style upvc conservatory. I think it was built by Anglian when the house was constructed in 2001. We've never used it as it was south facing and suffered from the usual too-hot-in-summer, too-cold-in-winter, and the noise is unbearable when it rains. Heat reflecting strips inserted into the polycarbonate roof helped, but didn't solve the heat build up problem.
Apart from a few holes in the outer layer of the 16mm multiwall polycarbonate roof panels, it is still water tight after patching up the holes.
I'm looking to 'extend' the life of the roof for as little cost as possible. Some if not all of the panels will probably have to be replaced.
The cost of converting the roof to a tiled roof is too high imho.
I noticed you can now buy EPDM rubber roofing kits for sheds, and I was wondering is it possible to glue the same material on top of existing polycarbonate roofing sheets. The edges can be held down by the existing roof bars? The EPDM may or may not help with reducing the noise from rain too.
Does anyone have any thoughts about this daft idea ?
