Conservatory roof, what do I need & where to get it from?
12 May 2016
Hi all,
First post so go easy on me!!
I’m building a lean to conservatory that is 5330mm wide x 2710mm deep & to date I’ve done the foundations, brickwork, all windows etc & now need to make it watertight with a roof.
I have all of the wood to create the rafters & hopefully this is where you guys come in to help me achieve the next step. To give you an idea of what it looks like etc there are a couple of pics here:
As you’ll see roof height is tight but there is enough room there to create the drop we need.
Had a quick nose on the net & found a website http://onlinepolycarbonate.co.uk & saw what they had to try & visualise what I need.
So far I reckon we need this lot:
4 x 16mm polycarbonate Roofing sheets length 3000mm x width 1050, tint: clear
1 x 16mm polycarbonate Roofing sheets length 3000mm x width 14000, tint: clear
2 x Anti dust breather tape (10 metres length) 16mm thickness
7 x 2.1 mtr PVC Sheet Closure Trim (for top & bottom sheets & the one exposed side)
6 x snap Fix Rafter Supported Glazing bar, white 3mtr lengths
So do you reckon the above is what I need, or is there something I've missed? Price wise the website above was about £420 delivered, is that good or is there somewhere else I should be looking?
Thanks for your help,
Russ
Try your local Builders Merchant. They usually have the roof glazing bars, single, double or triple polycarbonate sheets etc.
Far to expensive to be honest, seems to be cheaper to order online.
Main purpose of my post was to see if I have listed enough materials for the job.
