Constant drip from overflow in hot water tank in loft
17 Nov 2012
Lanarkshire
Hi, the steam in my hot water tank is condensing on/in the plastic overflow pipe and causing drip onto my gas box outside in the cold weather it can ice up badly any ideas how to stop this dripping
Cheers
CBW
26 Sep 2019
North
Steam? Is it boiling? A photo may help with your description.
22 Jan 2007
Do you mean the cold water storage cistern or the feed and expansion cistern? One is usually big the other one much smaller. If it is turning to steam you could have a major safety problem on your hands.
  • Thanks
Reactions: CBW
17 Nov 2012
Lanarkshire
Basically the water storage tank, heating comes on heats up the water in the tank which I think is then causing condensation to form in the pipe that comes out of the wall of my house that then causes a constant drip. Just wanted to know if I can do anything to stop the constant dripping?
8 May 2017
I think you are on the wrong track. It's not likely to be condensation ,but the water level in the cold water storage tank rising to overflow level. Check the level in the tank. There can be a number of reasons the level gets too high.
