I have just built a large extension and going to use a seperate fuse box to supply it. It will be 7 meters (Cable length) away from the mains meter.
I believe i would need to install a 80a isolater within 3 meters of the meter and use 25mm cable to the new fuse box. Is this all correct and is there any problems using 25mm meter tails over this sort of distance.
Thank you
Thank you
