Really hoping you can help.
I have just had my CH header tank replaced (in the loft) as it was very corroded and running continuously. I assumed that the ball cock was faulty and the continual flow was going out the overflow pipe. Header tank and new ball cock later and the continual filling of the h/tank continued, but not overflowing (therefore stays at the same level). When I say the water is continually flowing, it is but not with any pressure - so effectively, a continual top up (but not by water dripping in - it is flowing in). The water of course must be going somewhere, and last night, I ruled out evaporation, as this continues 24 hours a day, regardless of whether the heating is on.
I am assuming that I may have a leak under the ground floor. Everywhere else checks out ok.
I have a suspended floor throughout the downstairs.
I have no idea how long this has been going on for. I assume I could be causing considerable damage over time, if i do not sort it soon? Because of the amount the header tank is refilling, I imagine a stop leak additive will not work and the best suggestion is to start pulling up carpet and floorboards. Any suggestion in simpleton's language would be very much appreciated.
Chris
Chris
