I foolishly thought that a control joint in a wall was no more than a break in the wall but now I have read the book more closely it explains that I should use flat galvanised steel pieces to bridge the gap. Seems to make sense but it says that the steel should be embedded in the mortar with (only) the top side of the steel smeared with a thin coating of petroleum jelly which will enable the two joined parts of the wall to slide (bit like fish-plates on a railway line). I do not see the sense in this as surely the underside of the steel will be fixed to the mortar and hence there can be no independent movement between the parts of the wall. If they had said put petroleum jelly all round the steel I could see the logic. Any thoughts?
