Controls for new heating system (WB 30cdi + Megaflo)
8 Mar 2012
Oxfordshire
Dear all,
We're looking forward to having our new system installed, but have a question re the controls.
In our last house, we had a wired Honeywell room thermostat (with a combi), which allowed us to chase the desired temperature at different times of the day, e.g:
0600-0800 21C
0800-1700 18C
1700-2200 21C
2200-0600 16C
Our installer has suggested Honeywell's RF2 pack (Wireless enabled programmer (ST9420C) and Wireless room thermostat (DT92E)), but on reading the manual it doesn't look like the above is possible - only on/off at different times of the day with the room stat set to one specific temperature.
Are my thoughts correct? If so, could you recommend a different way of controlling the system to allow me to set different temperatures throughout the day?
I wondered whether the CM927 wireless room stat (which does have the capability to change the desired temperature throughout the day) would work with the ST9420C.
Thanks in advance for your kind help.
LCB.
With the pack 2 you set the times with the controller.
But the Pack 2 is a dual channel set up. Not what you need. As you have found the 921 or 927 are better suited.
I would reassess your installer - if he doesn't know the difference between the packs, then I worry.
Neither the ST9420C nor the Pack 2 are necessary.
The CM927 will give the required time/temperature control for central heating and a separate single channel timer, e.g Honeywell ST9100C, located near the cylinder can be used for HW times control.
