Hi there !
I am planning to reconfigure my domestic central heating and hot water system.
I need to convert a normally closed V4043H1056 2 port valve to a normally open V4032B1257 2 port valve. I appreciate that there will be wiring changes required as the normally closed 2 port valve does not incorporate a microswitch.
What I wanted to confirm is whether this is possible, that it is simply a matter of changing the powerheads ? I am assuming that the actual valve body it is the same in both of these 2 port valves ?
Many thanks.
Many thanks.
