Cooker hood ducts
12 Apr 2010
Kent
Hey,
Manufacturer's instructions say 125 or 150mm. Kitchen fitter says 100mm will be fine?
Will the hood warranty be voided by not using a size they mention?
Ta
I would always advise following the MI, but generaly they are over engineered recomendations.
But considerating should be taken in to the amount of extraction you require and the distance of extraction to grille.
Normally a cooker hood ex-fan would come with the 150mm outlet, so would need reducing down if you are considering that.
Is there a reason why you do not want to or the kitchen fitter does not want install fit 125mm/150mm duct?
Not sure on reason. Distance from hood to grill is probably 0.5m. It's literally up a tad, bend out and that's it.
The hood came with a 150>125 reducer so I will ask him to use 125mm duct.
If it is only a short distance, reducing should not compromise the efficiency greatly. But if you already have 150mm/125mm reducer, seems pointless purchasing another reducer to take it down to 100mm. And by using 125mm you are conforming to the MI.
