Cooker hood plastic Ducting Regs
27 Jan 2011
UK
I cannot find out if its ok to use plastic duct fittings - nothing recent anyway. I am looking at using Kair plastic fittings and although they mention cooker extraction they also state up to 60 degrees. Is that a lot - I don't know
Air drawn in, will be highly diluted in temperature, by air drawn in from the surrounds, so 60C will be fine. Put your hand under the intake when it's running, if you can happily keep it there, it is <45C.
Thanks everyone just wanted to double check as I know how fast regs change.
