core drilling 162mm for kitchen extractor vent
NHW
21 Jun 2013
instructions on my vent - eiQVENTKIT150COWL - Say that a 162mm minimum hole size is required for the kitchen vent.
I already have a trusty Titan TTB631SDS which has a safety clutch, but I am told that it shouldn't 'really' be used for doing core drilling, and that 162mm is quite a large size which should be used with a specific type of core drill - Hilti 110's / Makita DHR242Z etc. Which for drilling 1 hole I would not see the return in buying outright, renting I think is around £90 a day approx.
Not many places also have a core bit which is larger than 150mm, so the 162mm core bit I am just thinking to go and buy anyways.
https://www.toolstation.com/mexco-premium-slotted-dry-diamond-core-drill-bit/p30062
I'm just wondering if its just moreso a suggestion that you cant use the Titan for this type of job and that if you basically just take your time and go slow it would be alright. Its just for a normal residential property so brickwork, blockwork and a cavity. Thank you for any advice in advance
I had a 6” core drill and very rarely used it. Having said that when I needed it I had it in my garage
