core drills, to hammer or not
23 Feb 2006
Hi all,
I need to buy a small (about 1.5") core drill or something to make a hole in a wall, standard house wall 2 bricks thick with a cavity. I assume I'd use a core drill, but do I use it on hammer or not? The drill I will be using is a DW005 24V SDS which I assume will do the job. but do you use core drills on hammer or not?
ok, I tried and after ages I got half way through the brick, went and borrowed a friends bigger drill which is a dewalt 25600 sds max with an adaptor, but I got home and noticed it had no hammer stop, anyway it was 9 oclock and I needed to finish so I wacked it through, didnt seem to damage the core drill in any way.
After I looked at the spec of the drill and it gave a rating of 100mm for a core drill. My question is, why do they give this rating if you dont use them on hammer and this drill has no normal rotary mode?
ok whats the deal? the ones I got look like a tube with small nobbles on the end like this
I cant remember what it says on the box and Im not at home now to look. Should these be used on hammer?
buggers, no wonder my plan didnt go to plan! my drillprobably would have done it in that case
There are two kinds of core drill - tungsten carbide tipped and diamond tipped. You should never use hammer action on the diamond tipped as they are brittle.
Scrit
thanks,
all sorted now, the ones I have are tungsten, I assume everyone assumed I had a diamond when I posted originally, out of interest, I made another hole and used my dewalt cordless, went though no problem on hammer lol
