Corner shleves
18 Jan 2010
Hull
Hi there,
I want to make up some chunky 2" thick corner shelves out of oak, How do i go about fixing them to the (dot n dab ) wall with invisible brackets ? Ive seen the brackets used for staright shelves but these wouldn't work in a corner...
Any suggestions would be much appreciated..
In corners you can simply put screws into wall and place shelf on top, tap to mark the position of screws and cut a narrow channel half way thru shelf at screw points, then drop shelf on so screw are hidden up inside the slots.
