I have some contiboard left over from some shelves that I put in the wardrobe, I want to use the left over to make some shelves, these will be approx 600mm wide x 250mm deep, the conti is 15mm thick, I am wondering how to support these, taking into account that we will be putting books on them and the shelves will be going between the wardrobe and the wall (as its a new build home the walls will be plasterboard and I don't really want to put a fixing on the wardrobe.I don't want anything big, so I don't want the steel brackets that you slot brackets into, I would rather not use 'London Bracket', these might be covered by books, so you might not see them, but would like to see other options.I could use a wooden battern along the back and RHS and stop a couple of inches short of the front? Or how about:-
http://www.screwfix.com/prods/22233/Ironmongery/Brackets/Shelving-Brackets/Adj-Splash-Bracket-White
Say 2 on the back wall and then maybe another 2 on RHS wall (but nothing on left as that is where the wardrobe is.
I did look at the 'Pins' that you can get for 'Floating shelves', but that would mean drilling a hole in the thickness of the wood, and I can't drill straight, I would probably go through the wood.
Could I have your thoghts please..
Many Thanks
Steve
Many Thanks
Steve
