Hi
I am a novice DIYer and have encountered a bit of a problem... I was stripping wallpaper and unfortunately someone had papered up onto the cornice, the paint has flaked off in this area, I have continued to peel the paint off to the point where it stops coming off easily. The question is do I need to strip all the paint off the cornice? Or is there an easy way I can do it and end up with an even result - i.e. sanding with fine grade sandpaper to smooth the different levels of paint.
The cornice has been painted with several layers of oil based paint and there seems to be a red distemper underneath. The house was built around 1890. Also it seems like there has been a damp problem many years ago and some of the cornice has cracked. Can I fill these with polyfilla or should I use skim coat that I have used elsewhere in the flat?
Why oh why did I not buy a new build?????
Any help and advice gratefully received!
Fiona
Fiona
