D
Deleted member 18243
I have replaced a ballast in a 2 x 58w tube office light fitting. It now works OK but someone in the past has made a mess of the incoming mains cable to the fitting. This incoming cable (1.5mm T&E) mustn't have been long enough, and so it has been extended by joining a further length of T&E via a plastic terminal strip. Insulation tape has been wrapped around the join, and the "bulge" created almost touches one of the tubes.
Obviously I want to correct this, first by using a junction box in the ceiling above the fitting, and then running a new cable into the fitting from it. My question is what type of cable should I use? The cable will run about 200mm inside the fitting before reaching the terminal block. Do I need special heat resistant cable or will ordinary 1.5mm suffice?
Thanks.
Thanks.
