Our victorian house has an original loft room.
We had a re-roof done 9 years ago, and took the opportunity to have them install insulation above the ceiling before felting and slating the roof.
The job does not appear to have been the best as the chimney now needs re-pointing again, and the ridge tiles are coming loose, as is the lead flashing.
Of greatest concern is that one of the roof surveyors has informed us that we should not have had rock-wool insulation (the pink loft insulation type) installed as this can absorb moisture and rot the beams.
We are told that it it was done today then the regulations say would use Kingspan (or equivalent) to insulate.
Is this the case, and can the rockwool really be causing our roof to rot and eventually fall in on us?
(we had two other quotes and they said there is no visible evidence inside.)
It's not the horror scenario I was expecting when I asked for quotes.
We are unsure what to do, an inspection (removing a few rows of slates) could cost £1000, where-as 'doing the job right' is expected to cost £6000.
Thanks for reading - any advice appreciated.
