Hi all. Would appreciate some help from some experts. Several questions I'm afraid
1. I have a valve fitted in-line on the pipe from the bottom of my hot water cylinder coil and, whilst trying to find out what it did (I'm definately no expert), I messed with it. Now I'm not sure it's set correctly. It appears to be half-on, and speaking to a British Gas engineer, he said it was a bypass value and shouldn't be touched.
What is the easiest way for me to set this valve up to the correct position?
2. The cold water feed into the header tank in my loft is really really noisy - when someones taking a shower, the hissing noise of the tank filling is loud enough to be heard downstairs or to wake someone in the bedroom below. Can this be quietened?
3. I currently have a (ten year old?) ACL LP241 programmer and would like to change for a LP722. Is this possible? It is an easy DIY task?
4. Finally, I would be interested in getting 7x TRVs installed and would be appreciate it if someone could give me an idea of how much I'd be looking at to get them supplied and fitted
Many thanks in advance!
Steve
_________________________________
Lynda, moderator
please read forum rule 9
Steve
Lynda, moderator
