I have a double garage (7m x 7m), single skin brick wall construction, with double skin pillars every metre, and a huge RSJ running from front to back in the middle.
It has a cement/asbestos corrugated roof, that has most definately passed it's useable life (leaking all over the place)
I plan to replace the roof in the spring/early summer, and although would like to put a proper pitched roof on, I really can't see me affording to do that.
Would something like this be an appropriate direct replacement?
http://www.roofingsuperstore.co.uk/...ted-bitumen-green-roof-sheets-2m-x-950mm.html
If so, reading the PDF installation instructions, it says that a pitch of 5-10 degrees (my roof changes in height by 3 brick rows in 7 metres - so I think I fall into this catagory) the roof sheets should go over the top of close boarding or decking, rather than timbers at 600 centres.
The current cement/asbestos stuff if simply placed on timbers at 500-600 centres.... so boarding over once the existing roof has been safely removed is not at all difficult, but I just wondered if it is necessary?
Any thoughts?
Any thoughts?
