corsa fault codes
23 Feb 2008
Kent
Hi all i'm looking for any information about Corsa fault codes, i have the car with a spanner through it come up on the dash and the car went into limp home mode, i've checked the faults using the pedals, and the following codes come up.
P1120
P1122
P1550
P0105
The light is still on but the car runs ok at the moment, does anyone know what it could be?.
Hi thanks for your quick reply, I should have explained better i know what the codes mean, but i'm looking for more information about them.
well ive just googled the 1st code,p1120 code,
and it looks like the tps is a problem,as said google is your friend ;)
I think i'd check the codes again most codes normally read P0--- not P1--- but as gregers said looks like you may have a faulty tps (ignore the code about barometric pressure sensor) if the codes are what i think they are
Hi thanks for your reply i've checked again and the codes are right, why do you say ignore p0105?, this is the latest code.
P1120 tps
P1122 tps
P1550 speed sender
P0105 map
i'd be clearing all the codes then see if they come back, if they do then check connections, if clean and fault still there then replace sensor
