Corsa Y reg Rear Brake Light
15 Jun 2004
Norwich
Corsa Y reg, just changed the rear brake bulb (near side), now no rear lights on that side.
HELP
Bulb is correct.
As no lights are working that side, I'm think bad negative connection as that seems the common item. have cleaned terminals checked fuses, still no joy
Is there no life at all.....even the reverse or indicator?
Check the multiplug at the back of the cluster for any displaced pins - and then run a separate earth to see what happens after that.
John :)
Booked into garage, but today indicator works.
I'm fed up with it, bloody car electrics.
