Rear light going off when brake light comes on
WSB
27 Jul 2014
Hampshire
My Zafira rear lights work fine. My rear brake lights work fine with rear lights off.
But if I brake with rear lights on, on one side, no lights come on at all.
I have changed the bulb but that has made no difference.
Any ideas?
Dodgy connection?
A dodgy earth connection in the lamp cluster, more than likely.....assuming the correct bulbs have been fitted!
John :)
Thanks, pretty sure the bulbs are correct, as the problem only started occurring recently with the same bulb. Cluster looked ok at first inspection. Will give it a good going over and clean up over the weekend.
It could be a broken wire in the loom. Vauxhalls are notorious for snapping wires at any point that has a pivot and a wire runs through. Its notmally around the hinge area and you will see a black gromit between car body and tailgate. However to inspect you need to move the gromit away which can be hard. I would check the cluster first
