Cost of replacing a fuel supply hose
2 Oct 2005
Oxford
I've just had a problem with my fuel supply hose, it looks like it has been cut by someone wanting to steal petrol. I've sorted it all and taken it into the garage now but I was hoping someone could tell the approx cost of replacing and fitting this part? I drive a Citroen Saxo 1.1 if that helps? I did ask the garage but they said they would need to assess the problem first....I just wanna know what to expect!
Thanks!
________________________
moderator
please note 9 which is here
Depends on what they charge per hour. £100 should cover it, with some change. Good luck. Let us know the outcome.
Also depends on if the pipe can have the damaged section replaced,or if the whole lot needs doing.
e.g. if it is safe to just repair it,then it could be 50p for pipe,£1.00 for for a couple of jubilee clips,and half-hour labour
or,as Quickfit said,could be £100 if the lot needs replacing.
