Hoping somebody may be able to help.
I have a Vaillant boiler which is about 3 years old. Just before the winter kicked in I drained down the system as my installer had shown me (switch off boiler, twist red release knob under boiler until water begins to drain out and then open bleed valves on radiators to empty them). I then closed all of the bleed valves, returned the red knob to its closed position and pulled the black lever underneath the boiler to recharge the system. Usually when I do this there is a fairly loud hiss as the mains water charges up the system and it takes about 3 minutes.
THIS time however, there was a bearly audible hiss and the rads took about 2 hours to recharge. Any ideas why?
Also, I have ONE cold radiator in the house. This one has never been as hot as the others but now it's warm only at the top. Somebody suggested it may be the left hand valve (i.e. not the TRV) but I'm not sure. Prepared to replace both valves AND take the rad off the wall to flush it but would like to avoid this if possible. Any ideas what could be wrong?
Many thanks in advance.
KD.
KD.
